subject says it all;
looking for a pair of front king springs low for 260z;
If anyone has a pair lying around not getting used i would certainly be interested.
catalogue says they are part number:
KDFL-04
thanks,
thanks, but i already have a pair of 'off the shelf' lows for the rear, so i was ideally just trying to track down a pair of fronts in the low. Buying a new pair of fronts will most probably be my outcome but i thought i should ask if anyone had a front pair they were not putting to use
If you are going to buy Kings, then they can custom make springs to any size and stiffness that you want.
I wanted lower and stiffer springs than the standard lowered king's. I simply told them what model numbre I had, how much lower I wanted them and how much stiffer. They worked it all out, manufactured them and delivered them in a week. They even give you a part number if you want to make another set up the same. Might be worth considering?
Fairly sure,
I told them how much lower I wanted the car to sit, that's for sure.
I'd imagine they'd do something like:
-Assume weight of car
-calculate droop of new stiffness spring
-work out how long spring would need to be to sit at original height
-adjust length to sit at new height.
It's pretty simple maths. You either know how much the spring you have is drooping (also need spring stiffness, being a King spring in the car made this easy, just give a part number) and calculate the car weight, or know the car weight, or just assume (1100kg divided by 4 would be a good start).
