Hi,
I have two running complete L28 motors; one which has Toyota 88mm flat tops and the other with the normal dish.  The flat top version has a mild Bert Jones & Son 280 degree duration.  I am located in Brisbane.
Ross
A fellow member in Melbourne is also desperate.  I have a RB25DET/260Z project so don't need any the L28 motors I have collected over the years.  Both motors are running, one is standard from the existing 260Z and the other is from a former project which had the 2mm over-bore plus a few other goodies such as flat-top pistons, decked block (10/1 comp), ACT rego streetable cam, matched ports, 3-2-1 extractors, ram-tubes.  Both motors are complete with alternators, startor motors, dizzies.  Both have done around 100kms.  The 88mm motor was fully rebuilt and taken-out about 8 years ago after my 260Z was rear-ended.  I have other L-series bits and pieces including 5-speed gearboxes.  All need a good home.
