dat2kman Posted May 21, 2010 Posted May 21, 2010 Made for L series 6 cylinder, one only, bought as a spare, for my old race motor, ( still have one fitted to existing) It misses the rotating crank/conrods by 0.2 to 0.5mm and stops HP robbing oil mist and windage , and gets the oil back down into the sump quicker Laser cut and very accurate. Made in USA sell for $150 includes postage to anywhere in Australia pm or phone 0403 071 294 Quote
luvemfast Posted May 21, 2010 Posted May 21, 2010 Pics? If it fits under mains, is there any mods needed to be done to them? Quote
dat2kman Posted May 21, 2010 Author Posted May 21, 2010 get pics soon, basically it is a flat steel plate laser cut to clear all rotating assy, with from .2 to.5mm clearance, the clearance is adjusted by the very small amount of clearance in the holes in the scraper that the nuts (if using studs), or original main cap bolts into the caps. There are no mods needed to existing parts in sump. They even have laser cut the hole for the dipstick! It is made by a Co in the US called Ishihara Johnson ( google is good!) One only first in gets it. Quote
DatPilot Posted May 22, 2010 Posted May 22, 2010 I asked a local dat engine builder, he reckons that having some oil spash everywhere is good, like for the pistons/cylinders etc... is there any proof that this works?? if so i might go check my bank Quote
