Bruce Posted September 5, 2006 Posted September 5, 2006 The Nissan Car Club round of the VCAS Series is on again at Kyneton on the 16th September. It's a Twilight event with Scrutineering starting at 12 midday $45 to run, had a full field last year so get your entry in early Had a couple of Z's entered last year, so if you don't mind getting your car dirty, we'll see you there cheers Bruce http://www.nissancarclub.org.au/upcoming/UpcomingEvents.htm Quote
sid280 Posted September 7, 2006 Posted September 7, 2006 Hi Bruce Does this event require CAMS license? I've had a look around but cant see anything that confirms yes / no... Would probably be a good watch anyway... Sid Quote
Bruce Posted September 7, 2006 Author Posted September 7, 2006 gday Sid, you need Cams Licence (minimum 2S) and also a current membership to a Cams affiliated club. I am not sure if he entered last year but there is a Z owner who ran the previous year in his v8 4 wheel drive 260z 2+2. Very entertaining. cheers Bruce Quote
sid280 Posted September 7, 2006 Posted September 7, 2006 V8 4WD 260z 2+2 Please go on! I'm in the market for a 4x4 Any idea what drivetrain they used? Quote
Bruce Posted September 8, 2006 Author Posted September 8, 2006 Can't recall what it was running and I did a quick search of the net and can't find any more details on it. Pretty awesome machine, well engineered (and well driven) as it beat everything else on the day. Quote
zedevan Posted September 9, 2006 Posted September 9, 2006 i've heard about this car from a 260z owner, but couldn't find any info on it anywhere on the net. i was told its the fastest hill climb car in australia, either way it sounds impressive Quote
