260Z housings have provisions for 2 globes whereas 240Z have only one for the combined parker/indicator. Do you need both sides, left or right hand?
  • 4 weeks later...
  • 1 month later...
Do they have a parallel rubber gasket or a tapered one...I've got one spare body of the parallel gasket type, it has a small bulb...and I have one body of the tapered gasket type with a bayonet fitting but it's rusted through along one edge
  • 2 months later...
not all 240z are the same differs to the year , they are not all clear , or amber at that some have both park and indicator separated in the same housing which is much better depends on the year and to the month of build date, but then it dosnt matter as long as they are the same
If you are after the one with 2 light bulbs it may not be compatible with the 240Z wiring loom since the 240Z only had one light bulb. Connectors could be different as well? You may want to check this. Cheers.
