Hey mate, I can replace any loom that someone sends you at my cost. So if someone has one sitting around that they were going to use I can replace it for them if that helps.
I am still confused. By my definition "loom" refers to all the wiring in the car (all the way to the tail lights). But by the way you have used the word "just" I assume you are only talking about the portion of the loom between the ECU and injectors and throttle body.
No problem if my defintion is wrong.
If you are only after the bit between the ECU and injectors then Zedback may be able to help??? If he still has the one I gave him. If you are after the whole lot you'll need to talk to someone wrecking a car and it would take some efffort to remove all that wire.
thats the one sorry if i worded it wrong, thanks galderdi, i tried sport classics he tried to charge me a couple of hundred and that he meant probably 400 and he said that was only labour, told him i didnt want it then rudely told me to go somewhere else and hung up on me. never going back there again "EVER".
I had the same deal with him when I told him that the price he wanted for a 280zx that he had sitting there in his yard for 3 years was too much and he told me to get stuffed and hung up on me. If you can get back up to my place you can get the one out of the red shell parked in the driveway. But like I said I'm still stuck at work till the 18th.  ::)
  • 3 weeks later...
lol, i bought my Zed from there.  I rang him back when my car nearly caught on fire, he didn't want a bar of it, he is a tosser and doesn't deserve all the zeds he has.
