Going to get my Rb25det racecar checked on the dyno this weekend
How many rwkw will my RB25det racecar have
13 members have voted
  1. 1. How many rwkw will my RB25det racecar have
    • 170
      1
    • 180
      2
    • 190
      3
    • 200
      2
    • 210
      0
    • 220
      1
    • less than 170
      3
    • more than 220 (I wish)
      1
I'm going to get my racecar put on the dyno this weekend and thought it would be fun to do a poll on what everyone think the rwkw will be.
Its got an Rb25det running 10 pound of boost, Std computer, front mount intercooler, and straight out exhaust.
getting it done on a Dyno Dynamics Dynamometer in shoot out mode (don't know if this makes it more or less accurate)
Ash
How much power, depends on your dyno operator......A good operator should be able to give you what ever power you want ;D
Will be intersting to see how you go Ash.
Mine is on the dyno for it's tune in a coupleo f weeks after putting my old N42 head onto my stroker bottom end, I'm hoping for around 135-140 rwhp on the dyno I'm using, will be roughly equivalent to 150rwhp on a dyno dynamics based on previous results.
Well having a R33 some time back, mine made 220 rwKw at 15 psi on stock turbo.
I did so to try and see how far it woudl go and no issues.
I did have a different computer though.
I recon, stock fuel pressure, 10 psi, intercooler and exhaust.
160 rwKw, perhaps pushing 175
The best thing you can do for your RB25DET is fit a Nistune to it.
Then you'll have full mapping capabilities - you'll be near the limits of the stock ECU with your mods, and unable to maximise the potential of your setup.
Also fit a Jaycar IEBC for exceptional boost build :)
(My C34 Stagea was just over 140awkw with ~10psi, R34SMIC, and 3" dump)
I think you'll get over 170, but only just. There would be the potential for 180+ with a programmable ECU.
Ok all who said under 170 are right.
It made 160.7rwkW on 10psi boost
Mmmm now I want to put an ecu and stuff to get more :)
Think I will give it a run on the track first
Ash
Got it done at Chev's performance centre in Carrun downs 9776 8833
Really good bunch of guys. The owner Gary took his time and explained the whole process to me.
Cost me $100 which I think is pretty good
Ash
Power sounds about right for those mods on that boost.  Probably not much more than what your L series had?  But will have a lot more torque  :)
Definately go the new computer.  Should be able to wind the boost up a bit and easily get over 200 then.
