dalee Posted August 11, 2009 Posted August 11, 2009 Can someone please confirm that the DS and PS track control arms in 240z are interchangeable. I note that it appears that the only difference is the side the bushs project from the casting. Bushs are being replaced so this is not an issue. Also does anyone have an undamaged one FS. Thanks Dale Quote
Moderators Zedman240® Posted August 12, 2009 Moderators Posted August 12, 2009 I'm assuming you mean the front lower control arms? As you mentioned, with the bushes pressed in, there is a left and right hand and not interchangeable from left to right. I think from memory the small gap in between the crossmember and the arm goes towards the front. I think member "Mr Green" had some spare when I had a peek and bought some stuff from him. Quote
Scoota G Posted August 12, 2009 Posted August 12, 2009 I think what Dale is getting at is can you use the Drivers Side arm as a replacement for the Passenger Side control arm if you change the bushes! Quote
Moderators Zedman240® Posted August 12, 2009 Moderators Posted August 12, 2009 That's what i wasn't sure of..in that case...yes! Quote
