My water pump has stopped working. I've plugged in a fan and the lead has power so it must be the actual water pump. How do you test it with a multimeter? Am I looking for a consistent resistance?
Is it easy to remove from the car to check? usually anything with an electric motor, you can feel if it works; If you stick a multimeter across the leads you will just measure its resistance in the windings. Check it anyway but to make sure, I'd remove it and test.
