dat2kman Posted August 4, 2009 Posted August 4, 2009 It replaces the dinky factory fitted rubber band that is supposed to stop the diff flying up into the floor when the front diff mount finally snaps, it is made from 4mm thick steel strap, has two adjustable 30mm diam rubber snubbers on screw threads with lock nuts, and the tubes that your standard bolts go into are welded onto the ends of the strap and uses the existing brackets and bolts that the rubber band is fitted onto that attach onto your tunnel. With it fitted, and the rubber snubbers adjusted down onto the topside of your diff, it stops all up movement of the diff nose under hard acceleration. When you see it, you will say, "Oh Yeah, why didn't Nissan do this instaed of the rubber band, what a great idea" I have only one, dont ask for pics, I can work out how to do that, and yes I read the instructions on how to post pics, too hard for me. Just buy this You will be happy $100 pick up, or plus $10 posted anywhaere in Oz jason 0403 071 294 Quote
Cdr Zero Posted August 9, 2009 Posted August 9, 2009 Hey dat2kman, here's how I upload pics: go to http://tinypic.com/ Hit browse and find the image you want to upload hit open hit the big green upload now button wait a little bit while it uploads click on the section under (IMG code for message boards and forums) copy Paste into forums and post voila Quote
