howy z owners im new here im building a dirt curcit 260 z im putting a 253 into it has anyone done this befor? what i want to know is there any issuse with it and how do i get around the tail shaft? is it a matter of changing the yoke? also its going to be solid mounted.any help will be much apresiated
  • 5 months later...
Im all for being maverick and I can see the sense in using an engine that is widely available but this just seems wrong...
+1 for spawn
seems to be a lot of stuffing about for something you can get out of a motor that will be easier to put in!
what I really would like to see (in dream land) is if someone could get a 4.0L XR6 turbo motor in there... now that would be a lead tipped arrow
For Herrods
http://www.viczcar.com/forum/index.php/topic,5140.0.html
253260z, why stop at the 253? Is it a motor you really know or have? There are a lot of guys putting 351 and various other V8 motors in Z cars. They are generally american and can be found at forums.hybridz.org
Few guys have done V8 conversions in Australia as well and may chime in.
not gonna pass judgement on choice of 253
no great issue in getting 253 into a zed been done few times that i know of tail shaft is no great issue either use holden tail shaft cut it down and holden rear end off shorten tailshaft and fit datsun rear uni and coupling shaft or go the other way cut datsun shaft down and fit holden front to it
Mains issue with v8 conversion is getting it sitting back as far as u can to keep balance of car close to factory as u can otherwise gonna be pig and undrsteer
would need to make up plates that bolt to engine and allow u to put engine mount forward of orginal mounts so they line up with std cross member mount in zed this is well covered in jags that runs book on how to install 350 chev into a zed would be worth buying copy has install done step by step for 350 chev not same as 253 but very similar
also as 253 has dizzy at rear need to remover std bonnet catch system and make up new one so u can get dizzy about inch off firewall
plenty room for v8 in zed engine bay just need look at shorty headers that bring exhaust out and clear steering or make up some shorty headers
mick
Get the JTR book (and maybe even fitting kit) so you can easily mount an SB Chev in there.
The Castlemaine Rod Shop do v8 kits for the Z, as do MSA in Los Angeles.
Me personally - a stinking-hot SB if I had to. But with a few of these internet resources at your disposal, I'm sure you'll acheive it without too much fuss.
Why the crappy 253 they r wet why not go 4 a 308 same block and more power.Even a L28 out of the 280zx is better than a 2 fluffy 3. Just think all that time and effort for a crappy 2 fluffy 3 Please do somthing right and go 4 a 308.
