hi all this is going to sound real stupid :P but on my 260z 2+2, the round lights are they for high and low beam? or are those dim as lights next to the blinkers the low beams? can i change the set up? ie: change the round ones to have both high and a low setting.
also my blinkers are playing up, when i go to signal it'll blink 1 time then stay lit, its the same on both left and right sides. the electrics in this thing are strange ??? to say the least, i noticed 2 lots of wire going straight into the fuse box :o looks kinda like speaker wire. the radio of course doesn't work neither do half the gauges and hazard lights wont go on. i think i might need an auto elect :-[ lol
PS, is the 2 way button near the choke light work the antenna? my antenna is gone and when i push that switch either way i hear a vrrrrrrrrrrghn sound i figure its the motor for the missing antenna if not what the hell is it :-\
The round lights are high and low beam, the one on the bottom is the parker. as to the blinker you will need to change the blinker relay,and yes that switch is for the antenna.
Cheers Tony
Hey mate,
what i did when i got mine, was changed the parker globes, to the full strength 12v globes so they are much brighter. also i think you can change the mean headlight globes to any after market H4 globes.
hope this helps!
