Posted (edited)
Hi all, just wondering if anyone can help, I’m after the early 260Z type with square connector.
Cheers, Darren
Edited by Daza67
  • Daza67 changed the title to WTB - 260Z interior rear view mirror mount retaining plate and centre console hazard switch
The mirror has a metal 3-screw base plate with a black plastic surround trim, are you needing just the metal part or both?
I know of two hazard switch 5-pin wiring plug styles, early one being squarish in a beige colour and the later one more rectangular in white. And FWIW my FSM shows the same but with an in-built illumination lamp. What plug style are you wanting to connect to?
Yes I’m chasing the metal retainer plate, I purchased a new 3D printed visor mount, I am also after the early model hazard switch with square connector.
Thanks, Darren
  • Daza67 changed the title to WTB - 260Z hazard switch
I was given the retainer which was great 😊 Do you have the later type hazard switch? I don’t think it would be hard to change connectors. Cheers
The two variations of wiring plugs are completely different designs. My spare switch is the later style, so no good to you. Best you get the correct one so it's plug and play.
