Michael Posted June 1, 2009 Posted June 1, 2009 Hey guys, After Struggling to start the zed this morning i Finally decided to throw my spare Starter motor from the old 260z on "Larger in size Assumed it would handle turning the high comp motor better, Anway after Disconnecting to battery and throwing on the starter Dah Dah.. No Electrics will work at all, EG Lights/Starter Blinkers Nothing, Battery is still chaged because i can still run my Thermo/ Fuel pump of a Seperate switch Anyway any idea's guys? Im completely Stumped ><! * Threw the old starter back on and same problem, What could i have messed up oO!?! Quote
Moderators Zedman240® Posted June 1, 2009 Moderators Posted June 1, 2009 Did you re-connect all the wires onto the starter solenoid? The car gets its power from the same terminal on the solenoid that comes from the battery. Check also the fusible link and for anything else that has come off.. Quote
Michael Posted June 1, 2009 Author Posted June 1, 2009 Yep Checked it all, Twice, >< Will check again though Just to be sure Quote
