jasonb Posted May 8, 2009 Posted May 8, 2009 hey guys, sorry if its been covered, only got 2 mins left on break so i cant search and thought mayb by lunch some1 would be able to point me in the right direction but am i able to run 51mm struts with coilovers in a late 260 which has 55mm struts? thanx Jason Quote
Moderators Zedman240® Posted May 8, 2009 Moderators Posted May 8, 2009 In my zed, I had 55mm struts in the rear with no issues; I'm sure the fronts have the same casting at the stub axle/ball joint. I think the lengths are slightly different. Quote
zed240au Posted May 8, 2009 Posted May 8, 2009 trick i used when sectioning my 240z struts to lower car was to use piece of exhuast tube cut to fill space between shorter strut and length of strut housing was recomended to me by engineer works fine mick Quote
