zzzzed Posted January 10, 2009 Posted January 10, 2009 I was just reading on hybridz that the z31 turbo ecu and harness will run an l28et. Does any one know if this is true? If it is i was thinking of ruining one of these on my turbo 240z project and then running nistune Quote
dazzed Posted January 10, 2009 Posted January 10, 2009 im sure it would provided that you run a air mass meter and the early maxima L28 or RB30 dissy Quote
kalium Posted February 22, 2009 Posted February 22, 2009 Yes it will work apparently. an RB30 or Z31 AFM will work as well, although I believe that one of the wires on the RB30 AFM is switched to the Z31. It doesn't seem that simple though to get the right Z31 ECU, IIRC it has to be the 8bit (or was it the 16bit..). Ray Quote
