For Sale 1972 datsun 240z
Well after 2 years I have decided that I have to sell her its taking up to much of my time and I have other things that have more priority at this present time like wanting a Z32 TT!!
She has the full Rb30 conversion with her so it’s a matter of bolt strait in.. I have had the motor in and out so I know its all good..
1972 datsun 240z
This car was originally from Queensland used as a track car I have striped it and it has been garnet blasted and put into an white 2pac epoxy primer I only had parts of the shell garnet blasted as I wanted to strip the flat panels myself incase the garnet blasting warped them!!
The car was originally white but when I bought it was morone with 2 yellow stripes down it
The car has the following features
Rb30 Engine with reco head
New timing belt
Castle main hot rod conversion engine mounts
Castle main hot rod Oil sump
Castle main hot rod Wiring loom to go strait in the 240z rb30 conversion
Rb30 manual gearbox
Brand new pbr clutch
Wildcat Extractors
Brand new bosh Fuel pump
Brand new coil & leads
Steel ½ roll cage
Cams logbook
1 x 4.1 ratio R180 locked diff
1x reconditioned R180 single spinner
Triple core radiator
Mandrel 3” exhaust & muffler
Reconditioned 300zx 4 pot Calipers & disc conversion
Saab rear discs/ford Calipers
Bias valve for brake adjustment
Adjustable strut tops (f&r)
Adjustable sway bars on Rod ends
Strut braces front and rear
Modified fuel tank with inbuilt serge pot
Rose jointed lower control arms
Bump steer blocks
Shortened steering arms
Vdo tacho with shift light
2 x Mitsubishi FTO seats in excellent condition no conversion rails though
15” Mags 7x15(f) 8x15®
Brand new fiberglass Zg flares
Front spoiler
Rear spoiler
Isolation switch/ battery in wheel well
Fire extinguisher
Adjustable Suspension With lovel springs race spec
What it needs!!!!!
I Swapped the bonnet & hatch for the flares as i didn't want fiberglass items!! Thats why it needs bonnet and hatch
The Body needs work new floors,sills, around the tail lights needs attention the roof around the sills needs attention the rails under the floors need attention the positive is that you can see everywhere that needs attention.
Needs!!!
P/s window
D/s door because the one that comes with it has been chopped for race purposes
Bumpers
It has about 70% of the interior in dark maroon color
Needs bonnet & hatch
The Dash needs a restoration as well as the center console!!
Heater
Looking for around $8,000
Any questions please call James on 0433 716 157
This car will be going on ebay soon I wanted to let you guys have first pick at it tho….
This is it going around the track.. Marone one with yellow stripe
http://www.digitalrealism.com.au/supersprintb/gp11and12/images/
