mrp69 Posted October 29, 2008 Posted October 29, 2008 hey guys who supplies these and where can i get it from or you have some you sell let me know peter Quote
RBZ 260 Posted October 29, 2008 Posted October 29, 2008 not sure where u from but some national stores like: coventry fasteners should have stainless steel ones for you. chrome u got to get them done your self to normal bolts through chrome plating place. stainless is lot better and more robust. chrome does chip and rust eventualy. as for rubber i guess Clark rubber (are nation wide i think). they should have it but go to a larger outlet for bigger selection. Quote
mrp69 Posted October 29, 2008 Author Posted October 29, 2008 been to clark rubber they dont have the right one but will look up the fastners place to now and check em out peter Quote
RBZ 260 Posted October 29, 2008 Posted October 29, 2008 in Adelaide i use Fitch the Rubber Man. pretty much has everything including the inner door trim windows seals etc... but they are smallish business and dont have interstate franchise, which doesnt help you. other than that i guess try yellow pages for rubber specialist. I used same stuff that u after on the inside of the bonnet edge to finish off the hood heat shield. Quote
viking Posted November 11, 2008 Posted November 11, 2008 I believe somewhere there was a similar discussion and the rubber answer was the Volkswagon fender rubbers. The blind bolts were also discussed. If someone finds the subject can they link it here? Quote
