If you are considering installing a front air dam/spoiler on your Zed but concerned about the fragility of fiberglass etc. then maybe this is for you.
I have an unused one that is still in its box. It is urethane so will not crack/split if you bump the gutter etc.
Here are the details : https://shop.teamxenon.com/products/3125
As it was designed for the USA/Euro 260/280z models with the front indicators mounted above the bumper it will require you to cut the holes to insert/mount the front parker/indicator lights on your 240/260z.
Selling for $300
