luvemfast Posted October 6, 2008 Posted October 6, 2008 I have a spare L28 ready to rebuild. Can anyone recommend a parts supplier for a full rebuild kit? Also want to put a more aggressive cam in, recommendations. More than likely a regrind, so thicker lash pads will be needed too. Thanks for any help. Quote
Scoota G Posted October 6, 2008 Posted October 6, 2008 Sulio mentioned a fella in Melbourne who makes thicker lash pads. It's in a thread under engines on page 2 that i started called Thicker Lash Pads. When i rebuilt my L26 i shopped around. Bursons had the best price on anything other than the valve regrind kit which i got from Autopro. The rings i bought off Evilbay from a guy in the States called enginesellinman for $10 for a new set of hastings rings. Hope that helps. Here's an ebay search i did just recently http://cgi.ebay.com/ebaymotors/Nissan-280Z-280ZX-New-Piston-Rings-4394-STD_W0QQcmdZViewItemQQ_trksidZp3286Q2em63Q2el1177QQhashZitem310089973637QQitemZ310089973637 Quote
260Coupe Posted October 7, 2008 Posted October 7, 2008 Try Camtech, they have/had billets in stock http://www.camtechcams.com.au/ They supplied my 70/30 cam and is it was ground from a billet it had a stock base circle hence no fat lash pads.........Or if you do need thick lash pads Chris Wood can machine (NDSOC member) . PM me for a parts supplier if you like cheers Alan Quote
