mrp69 Posted August 16, 2008 Posted August 16, 2008 hey guys ive got a dim headlight on the passenger side would like some help fixing it will give a reward to the person helping (box of beer) peter
Scoota G Posted August 16, 2008 Posted August 16, 2008 Hey pete, It sounds like it's just a blown fuse, that's what happens with the headlights when you take the fuse out.
mrp69 Posted August 16, 2008 Author Posted August 16, 2008 hey mark, check all the fuses looks like a and earthing problem peter
Ben Posted August 16, 2008 Posted August 16, 2008 Earthing is done via the high-beam switch. The Z uses individual left/right fuses for the headlights, and when one fails, the lights on that side go dim (I'd draw a circuit diagram, but it's just too damn hard...). Double check the fuses, swap them over & be 100% sure that they're ok.
mrp69 Posted August 16, 2008 Author Posted August 16, 2008 ok well ive check the fuse box on the right hand side in the cabin all are fine are there anymore fuses in the engine bay?? peter
silverz Posted August 17, 2008 Posted August 17, 2008 Same thing happened to my car, passenger side Head light worked but was very dim. Turned out to be one fuse in the fuse box inside the car had fallen out of the fuse holder. I don't think there are any other fuses under the bonnet, at least not on my 240Z. Recheck your fuses, remember there is a Left hand headlight fuse and a Right hand headlight fuse. Regards Peter
Ben Posted August 17, 2008 Posted August 17, 2008 Actually, while I think of it, what year/model car are we talking about here? And where are you?
mrp69 Posted August 19, 2008 Author Posted August 19, 2008 hey guys problem solved wasnt the fuse is was the fuse box wire had burnt behind it $50 later all fixed better than getting some auto electrician to charge me $80 and hour and tell me he needs my car all day the bloke came to my house and i watched him fiddle with it all 1 hour later problem solved if any1 want a good auto electrician who will come to your house pm me peter
