Roady Posted December 18, 2020 Posted December 18, 2020 Tried installing a new coupler today (got the old one out with some wriggling) but after battling with the bolts for an hour I’ve given up for the day. Will undo the 4 steering rack bolts tomorrow to make is easier unless anyone else has any suggestions?? Cheers gilltech 1 Quote
Roady Posted December 19, 2020 Author Posted December 19, 2020 For the record (anyone one else doing this) - this could be around a 20-30min job. It all depends on where you, previous owner has the steering linkage positioned and if you have a steering column which has some ability to lengthen. In my case the linkage was at its maximum length and therefore the steering column had no adjustability, meaning I needed to create room. Don’t waste time trying to move the steering rack - I recommend you undo the 8 bolts of the steering column (4 fire wall and 4 under the dash) and pull the steering column slightly (1 inch) into the car, then you can fit all bolts and new coupler first, then re-connect steering linkage. Whole process would take about 30-60mins... Not 3 hours as I have just managed! Good luck Quote
