Posted (edited)
Wondering if anyone has mucked around on a Dyno to get any actual figures if they had success altering the spark plug gap?
Not talking about installing a high energy system as you’d be able to expand the gap then obviously, but as I said wondering if anyone has played around with this after other modifications such as increasing compression etc. then gone up to 1.2-1.3mm or back down to 0.9mm as an example.
Using L28 NGK plugs, as I’ve got an L28 engine with a Mitsubishi electronic distributor (not points). Standard gap of 1.1mm
Edited by Roady
