Wondering if anyone had a 240z / 260z choke cable spare at all?
Wanting to make up a choke cable for a set of triple solexes however would like to keep my original cable for the twin SU's intact.
Mine is a '73 240z.
Hi mate, You really don't need choke cables set up because the carbs have pump jets. Couple of pumps on the accelerator pedal and it should start. It will probably be a bit hesitant till it warms up a bit but better than fouling the plugs with the chokes on too long. Looks neater without the extra cables as well.
David.
Hi David,
I had tried that actually - anything from 1 to 4 pumps, sometimes with the foot on the pedal when cranking. Still having difficulties starting the triples on first go. Sometimes it takes many attempts which can be a little embarrassing in parking lots with lots of people around.. Was hoping the choke cable might fix this.
From what i've read triples usually start quite nicely?
Hello again, I would take the time to correctly have the carbs tuned instead of wasting time with choke cables. If the carbs are jetted correctly it should just take a couple of pumps to start the car. I ran triple Dellorto's on my engine years ago and had no trouble starting the car because I spent time with correct tuning. If this is something that you cannot do I would find someone local who has experience with triples. Good luck. David
Ok thanks David. I'll give them a proper tune and balance again this weekend just to make sure everything is setup correctly. Hopefully that takes care of things.
