RAP260 Posted November 9, 2019 Posted November 9, 2019 (edited) Afternoon all The distributor ( unilite ) is getting 12v. And I've tested the resistance on the coil, which seems to be within the recommended ranges. Was warming the car up to go for a run, and it just stopped, very suddenly. Fuel pressure is good. Checked all the fuses. Cheers, Rob Edited November 9, 2019 by RAP260 Quote
RAP260 Posted November 9, 2019 Author Posted November 9, 2019 Tried the white wire test procedure, per msd instructions. Definitely not working. So it's either the coil or the controller, just don't won't to start replacing parts ad-hoc. Don't have a spare coil unfortunately and I really wanted to avoid rewiring the ignition system, just to check the coil. Any one got any other suggestions for testing a coil, other than resistance? Quote
RAP260 Posted November 10, 2019 Author Posted November 10, 2019 Problem solved. One dead 6al. Rewired the coil / distributor , fired straight up. Time to go buy a ballast resistor and bin the 6al. Quote
