Question
3 answers to this question
  • 0
Posted (edited)
On 10/21/2019 at 4:47 PM, Damien said:
Hi, suggestions on bush kit for 260z?
Unless you go aftermarket urethane (nolathane/prothane etc. etc.) then you will not find a kit as such.
I put new "rubber" ones back in mine as (other than the steering) I feel the OEM type were made to suit the application especially the suspension - hence having to tighten the lower control arm bolts holding the bushes when the vehicle is on the ground and loaded with 2 people and a full tank of fuel.
PS: The MSA website has some good advice regards still using some rubber bushings in certain areas : https://www.thezstore.com/page/TZS/PROD/23-4100K
Edited by AndBir
added MSA link
Answer this question...
