Bobby Posted June 30, 2019 Posted June 30, 2019 I have for sale a Cannon inlet manifold and the linkages for three Webers that was on my 260Z when I bought it. None of the studs that hold the carbys were square to the face-I have corrected this and made all to a length for soft mounts. Where the bolts go through the manifold to mount it to the head was not flat-I have milled all of these to give a consistent thickness which makes it easier to match to extractors. I have made up new mounting points for the three support rose joints to get better actuation onto the carbys. Note to get the rod as close as possible to the carbys I machined a little off where the choke cable would be. You will either have to do this or go back to the original setup for the rose joints. I have made all the linkage you see in the photos including the universal joint. Manifold has been vapour blasted for a more durable and better looking finish. My carbys were 40mm so I don't know if they are all the same externally. $300 I live at Newcastle NSW. Quote
Bobby Posted July 3, 2019 Author Posted July 3, 2019 Thanks to all who were interested. This has just been sold. Quote
