Kent Posted August 30, 2018 Posted August 30, 2018 Hi guys, Does anyone have an R180 lying around they don't need? I am after a later "K" designated one with the larger 115mm ring gear but still with bolt in stub axles (that's what my LSD centre needs). Preferably the 3.9 Ratio Thanks Kent Quote
Retro Z Posted August 30, 2018 Posted August 30, 2018 I have one from a 72 manual 240z. Unsure if its the K one though. Missing the bolt in axles and companion flange as i used it for my other diff. Quote
Riceburner Posted August 31, 2018 Posted August 31, 2018 Might be worth try Subaru wreckers as well Kent, not 100% but I believe they are the same, just the spline count in the diff centre is different. That won’t trouble you as you’ll swap in the LSD diff centre to suit the Datsun axles. Quote
Kent Posted October 1, 2018 Author Posted October 1, 2018 all sorted now thanks to @ZED660 and @Riceburner, Thanks guys! Quote
