Groundhog Posted April 25, 2018 Posted April 25, 2018 (edited) Engine and underbody P-clip bushings no longer available- reproduced via 3-D printing.260Z Engine bay kit of P-clip bushings. (Reproduction) Contains4 x Small three hole clamp bushings- Fuel and brake line9 x Small 1 hole clamp bushing- Brake line 1 Large 4 hole block - Fuel supply, return, vent and brake lineCost $50 plus postage 260Z Complete car kit of P-Clip bushings (Reproduction)Contains4 x Small three hole clamp bushings - Fuel and brake lines10 x Small 1 hole clamp bushings- Brake line9 x Large 4 hole block Cost $95 plus postage Engine bay wiring harness 3 hole straps (Reproduction)Minimum quantity of 10 - Cost $40 These costs are low to recover printer setup, materials and CAD drawing costs.Please do not ask for single clamps as it is simply not worth the time to set up a 3D printer to print low volumes.Other clamps can be produced on request however there are minimum quantities of 10 to make setup worthwhile. Edited April 25, 2018 by Groundhog Quote
Groundhog Posted April 26, 2018 Author Posted April 26, 2018 The filament used to check for finish and flexibility was TPE. There are many available and an alternative was TPU. However I am happy with the finish flexibility. You can see fine printing lines up close, but you need to be 6" away to see it. Not for the concourse restoration. Quote
