Posted (edited)
Engine and underbody P-clip bushings no longer available- reproduced via 3-D printing.
260Z Engine bay kit of P-clip bushings. (Reproduction)
Contains
4 x Small three hole clamp bushings- Fuel and brake line
9 x Small 1 hole clamp bushing- Brake line
1 Large 4 hole block - Fuel supply, return, vent and brake line
Cost $50 plus postage
260Z Complete car kit of P-Clip bushings (Reproduction)
Contains
4 x Small three hole clamp bushings - Fuel and brake lines
10 x Small 1 hole clamp bushings- Brake line
9 x Large 4 hole block
Cost $95 plus postage
Engine bay wiring harness 3 hole straps (Reproduction)
Minimum quantity of 10 -
Cost $40
These costs are low to recover printer setup, materials and CAD drawing costs.
Please do not ask for single clamps as it is simply not worth the time to set up a 3D printer to print low volumes.
Other clamps can be produced on request however there are minimum quantities of 10 to make setup worthwhile.
Fuel%20brake%20CAD%20drawings_zpssxjtil5
Edited by Groundhog
The filament used to check for finish and flexibility was TPE. There are many available and an alternative was TPU. However I am happy with the finish flexibility. You can see fine printing lines up close, but you need to be 6" away to see it. Not for the concourse restoration.
