Hello Guys,
                  I came upon this on Hybrid Z by accident. An Ignition module for converting your existing distributor. You can disconnect the vacuum advance and lock the mechanical advance and programme the distributor on a laptop computer. Handy for old distributors (especially if the vacuum advance diaphragm is stuffed) or if you want to keep the original look.
Will fit 4, 6 and 8 cylinders, good for 10,000rpm, programmable vacuum and mechanical advance. $200.00 usd.
https://www.cbperformance.com/product-p/2013.htm
