maddos Posted March 13, 2018 Posted March 13, 2018 Hi all. I’ve pulled my brakes apart for rebuild and the front right caliper had pistons seized due to failed seals. I think the bore will likely be stuffed so am either looking for a new caliper in condition suitable to refurb or possibly the S12+8 upgrade. I have already mistakenly purchased a set of S 12 W calipers which seem a bit large and aren’t a direct bolt on. Any options welcomed. Cheers Maddo maddos 1 Quote
dat2kman Posted March 14, 2018 Posted March 14, 2018 Have a set of S12+8 calipers. (They will need rekitting with new seals.) Can pack n post $250 all up. Quote
Administrators gav240z Posted March 14, 2018 Administrators Posted March 14, 2018 Before buying a new set, probably should confirm they really are stuffed.. I found stuck pistons on calipers but the bore was ok, just the pistons had some corrosion / damage. Quote
maddos Posted March 14, 2018 Author Posted March 14, 2018 Yeah think that’s what I’ll be doing. Spoke to the local brake and clutch place yesterday and it’s about $130 each side. Plus whatever pistons cost extra. Quote
