Triple 40mm Dellortos....SOLD FOR $1000 DELIVERED,GOTTA LOVE EBAY
Triple 40mm sidedraft Dellortos,rejetted and rekitted,comes complete with new Redline manifold(cost $385 on it's own) suit L6,new linkages etc
Located Perth
Will post to eastern states (work on $50 postage tops)
$1000
Hello,
      You mention that the setup is complete, but the "O" ring rubber anti-vibration gaskets are missing between the carbs and manifold. Also the bolts are too short ( should be studs ) and should have either rubber grommets or  thackery washers fitted. The linkage is not correct for a zed .The middle carb is different from the outer two. It has external adjustable idle mixture screws whereas the outer two carbs have the screws inside the towers. Can you list the part numbers on the carbs and what jetting and choke tubes are fitted in each carb. Sorry to be picky, but just like to get an accurate picture of what you are selling. David.
I think the ones with the internal/external mixture screws are just different revisions eg. older and newer models. I don't think it will make any difference in performance, as long as they are all jetted correctly. They all  are DHLA 40's. They must have the softmounts though! Very imoprtant unless you don't care about the needles and seats!
DHLA40G stamped on all three carbies
not sure on jet sizes,to suit a 2.6L nissan...sorry I am a fuel injection guy :(
i take your word about the rubber spacers,they have not been fitted to a car on that manifold,just loosely bolted on to show and mock up throttle linkage
i am sure anyone with enough basic mechanical knowledge to bolt the carbies on could get the throttle linkage pictured to work on an S130....if not best leave your car standard ;)
there is a difference between 'complete' and 'complete with',one suggests everything you need the other suggests it comes with extras....you'll notice it also needs air filters to be 'complete'
i am no carbie expert,hence the 6 pics,if they don't look like what you are chasing please don't feel obliged to buy them or bag them
genuine buyers i will try and provide answers to your questions,ask away
cheers fellas/gals
  • 3 weeks later...
  • 2 weeks later...
  • 2 weeks later...
  • 3 weeks later...
  • 4 weeks later...
