Hey all,
Many many posts about will this size fit etc but nobody seems to touch on the subject of wheel track.
Can somebody with 15x8 0-offset wheels on a 240z tell me what the wheel track is front and rear?
Legal front is 1381mm
Rear is 1373mm rear
If you don't get a full response then it's not too hard to work out what your track is, if you know what the offset of the stock wheels is.
Standard wheel offset is 15 mm as stated in  the factory workshop manual and the same measured on my standard  five inch wheel.
If you use a zero offset wheel, that will widen the track by 15 mm on each side giving a total track increase of 30 mm.
Giving front track    1386
           rear track     1377
I hope this helps.
           rear track     1377
I hope this helps.
Thanks Peter, that helps. I had no idea what standard track or offset was
