Due to a change in direction, I am regretfully selling my LCR built P90 head.
This package has never been run & is in 'as new' condition.
Specifications are:
New 46mm Stainless Intake Valves.
New 35mm Stainless Exhaust Valves.
New Valve Guides.
Refaced Rockers.
High-side Steel Retainers.
HSD valve springs.
54.5cc Chambers.
Manifold face has been drilled & tapped for an LCR external coolant rail - blanking plates included.
Injector notches have been welded up.
New Freeze Plug.
New Nissan Oil Gallery Plugs.
New Nissan Rocker Cover gasket.
New Kameari MLS Head Gasket.
Near-new Rear Collant outlet
Water Jet Blasted Head & Tappet Cover.
Ported by Les Collins.
Intake port flow (average): 228cfm @ 28" of H20 on a 90mm bore plate.
This head flows enough to make 380hp at the flywheel!
Camshaft is NOT included with the sale.
Thermostat housing assembly NOT included with the sale.
Full 'spec sheet' is available to prospective buyers ONLY.
Free freight to anywhere in Australia for the buyer, however pickup is preferred.
Price: $8,000.00
Contact: PM me here or CALL: 0400 054 572 if you are seriously interested. No time wasters please.
