Andrew_L26 Posted February 28, 2016 Posted February 28, 2016 (edited) Hi all, I've finally sourced a gearbox with a slave and master cyl. so now I'm just after: Either a 260z Clutch pedal or brake pedal 260z Clutch pressure plate Flywheel Clutch/throw-out bearing etc. (I'll probably just buy new) Rear Main seal (I'll probably grab one off ebay) If I have missed anything please let me know, Thanks All! -Andrew Edited February 28, 2016 by Andrew_L26 Quote
Moderators PB260Z Posted February 28, 2016 Moderators Posted February 28, 2016 Hi Mate Well done on finding a gearbox, is it a 260 one ?, if not you will need a 260 shifter. Also you will need both the brake & clutch pedals from a manual car. Cheers PB Quote
Andrew_L26 Posted February 28, 2016 Author Posted February 28, 2016 Hi Mate Well done on finding a gearbox, is it a 260 one ?, if not you will need a 260 shifter. Also you will need both the brake & clutch pedals from a manual car. Cheers PB Yeah, it's out of a 75/76 model (Which will hopefully be fine with my 78 2+2), Locky suggested that I could just grab a brake pedal, bring my pedal box down and he would modify it all to function correctly. Thanks, Andrew Quote
