aircobra Posted November 24, 2015 Posted November 24, 2015 I'm after the brackets that are welded to the longitudinal frame members and to which you bolt the rear bumper bar brackets They are what's behind the holes here http://240z.jeromio.com/images/gastank/CamaroGasTankComparoRear.JPG 260z is different. Either the brackets drilled out or a section cut will be OK Quote
