Richard, see my reply to your post on the other forum, I just got one from Demon Tweeks.
Basically two types, weld on or bolt on to your existing hub. I got a bolt on, not too sure about weld on, and I can change from car to car.
Only thing you have to worry about is the brand of steering whell. Momo and most others are 6x70mm PCD. I use a Personal wheel which is 6x74mm PCD so also needed an adapter ring.
Once my seat mount is done I will then decide if I need a normal hub or a shorter hub to get the wheel in the right position for me.
The cheap ebay ones don't inspire confidence, the motorsport types with a nice big shaft look much more solid.
