240z71 Posted January 23, 2015 Posted January 23, 2015 Hey guys, after searching and spending countless hours reading I have established that as I want to tackle one panel at a time fixing rust and priming as I go that I should use epoxy primer so it can sit around until the whole cars ready. I was however wondering what epoxy priming products are safe to be used at home in a garage whilst still being good at meeting the demands I'm after Thanks Quote
Roberto Posted January 23, 2015 Posted January 23, 2015 I have used and recommend Spray Chief 2 PAC epoxy primer. It is ISO cyanate free. Quote
240z71 Posted January 24, 2015 Author Posted January 24, 2015 I have used and recommend Spray Chief 2 PAC epoxy primer. It is ISO cyanate free. That would be there 4 -1 epoxy http://www.spraychiefcustompaints.com.au/TDS/Epoxy%20Primer%20(4-1).pdf ? can you buy it off the net? Quote
Roberto Posted January 24, 2015 Posted January 24, 2015 That's the one. I'm not sure if you can buy it on the net. Best call them for that. I buy it from JP Paint and Panel in Adelaide. Quote
bryan3976 Posted January 25, 2015 Posted January 25, 2015 invest in a respirator with a carbon canister and some ppg dp40 Quote
