Brisbane only, Steel rims from any Z, no care if rubber shagged
After steel only Z rims, condition unimportant, dont care if rubber fitted or not.
Reqd for fitting to chassis/bodies to get rolling.
When finished, will end up as hose reels or garden sculptures,,
briabane pick ups only !!
Jason. Want your old rims back? The ones I bought off you for the 1600? I've just had my third so pickup over the next few days will be tricky.
Jake has a set on his 240 for rolling around the panel shop atm.
It will be coming out in late jan and the wats will be going on so you could probably borrow them if your still looking.
