Hi guys. Wondering if anyone could recommend me a place to wire a manual rb25det into a 74 260z 2-seat. I have the full r33 doner car on hand with all the factory wiring etc aswell as the 260z with all the stock wiring also. Engine is already installed (waiting on a sump). Ready to tow it to whoever can do the job, or can even send both looms (then they send back complete) prefer someone who has performed the work before and must be in Melbourne unless i send you the looms. I have a budget of about 1k for the wiring with stock ecu, but flexible.
Thanks.
If you get stuck there is a sticky over on hybridz on how to get the job done
I am hopeless at wiring but I managed to get my rb25 wired up in my 240z by following it.
HybridZ definitely has a good write up. I would give it a go yourself, I've done the conversion for a mate in VL commonwhore and it's not that bad.
All depends on how much time you have  :)
I have a R33 engine harness and stock ECU installed into my car, I put it in myself.
Its pretty easy, I could walk you through it if you want to get your hands dirty.
Thanks guys. I'm not confident enough to do the wiring myself and don't want to make a mess of things. Benny has put his hand up to do the job, so the car will be off to him shortly. Thanks for all the help ;)
