andyk_79 Posted July 7, 2014 Posted July 7, 2014 With not having my car at home at the moment but trying to organise parts, I'm trying to work out what brake booster I need to order. I saw somewhere that the autos came from factory with the bigger booster (and different stud pattern) that was not fitted to the manual till 73, but was hoping to get some more surety. Would be a simple case of grabbing the tape measure if the car was here - so frustrating!! So can anyone confirm - do I order a 73 onwards booster ? I won't hold anyone responsible for their posts! Quote
Retro Z Posted July 7, 2014 Posted July 7, 2014 You will need the smallest sized one. 73 onwards the boosters increased in size 3 times on the s30's. I know this as my 240z is a 73 and i had a 71' parts car and the 71 booster did not fit along with the pedal box as the firewall holes are different between them. I also purchased a 75 260z and late 2+2 booster which was also different again. 70-72 -smallest booster 73-74. (240z and 260z) 2nd smallest 75-76. Bigger again 77-78. Biggest Not sure about manual or auto but my 71 manual booster is now on a friends 72 auto. And my personal 240z 73 was an auto is using a 74 260z manual booster. Quote
andyk_79 Posted July 7, 2014 Author Posted July 7, 2014 Thanks - if your 71 manual went onto your friends 72 auto it sounds like the autos had the same size (and therefore same stud pattern - there was a difference in stud patterns between 71 and 73 from what I understand). Will go with the option of getting mine rebuilt then rather than trying to source a replacement. Reduce the risk ! Quote
