camelofthesea Posted April 20, 2014 Posted April 20, 2014 Hi all, have had a bit of a look around for info about converting to power steering, all I could find are posts talking about converting the reciprocating ball power assist steering to the rack and pinion setup, which seems to be pretty difficult. What I have is a stock NA 280zx, fist year model with non-powered rack and pinion steering. I was thinking that as they later made the zx with power R+P, would a power rack and pump from a donor car essentially "bolt on" or at least come close? Quote
44014 Posted April 20, 2014 Posted April 20, 2014 Yep just bolts in. You will need the pummp all the lines and the power steering rack. Quote
imackz Posted April 22, 2014 Posted April 22, 2014 Hi all, have had a bit of a look around for info about converting to power steering, all I could find are posts talking about converting the reciprocating ball power assist steering to the rack and pinion setup, which seems to be pretty difficult. What I have is a stock NA 280zx, fist year model with non-powered rack and pinion steering. I was thinking that as they later made the zx with power R+P, would a power rack and pump from a donor car essentially "bolt on" or at least come close? yes have done it to my 79 datsun 280zx, get the crossmember as well , makes life alot easier Quote
