Hi peeps,
I've just converted my auto 240z to a manual but am missing the manual pedal box.
Does anyone have one spare. Happy to pay. I am in the south eastern region of Victoria. (Dandenong area)
Thanks
Cheeky
You can use your existing pedal box. Auto pedal boxes have a provision for a clutch pedal.  So all you need is the clutch pedal itself, bolt, bush and the spring.
You can also modify a spare brake pedal to work as a clutch pedal if you have an oxy and a welder.
Thanks, for the info. Don't know where I can get a clutch pedal, bolt and spring from do you? lol Otherwise ill have to try your other option you mentioned.
Thanks for your help.
