HS30-H Posted March 16, 2014 Posted March 16, 2014 The two Kanji characters ( they are upside down in your photo ) read "Kyoku To". 'Kyoku To' means 'Far East', and your manifold was manufactured for a company called 'Far East Trading', better known these days as 'F.E.T.'. Quote
salty Posted March 16, 2014 Author Posted March 16, 2014 thanks for that, any idea what its worth Quote
HS30-H Posted March 16, 2014 Posted March 16, 2014 Depends a lot on what application it was originally designed for. F.E.T. made the L6 fitment for all sorts. So it could be for narrow engine bay ( C10, C110 Skyline etc ) which is a shorter, slightly stepped design, or it could be for wide engine bay ( S30, S130 Z for example ) which was longer and straighter run. It will also be more likely to have been designed for the more common L20A and L20AE engines, so will be small port, small runner type. They did make them for L24, L26 and L28 but they are much rarer. Worth less without the proper linkage too. Quote
scott Posted March 16, 2014 Posted March 16, 2014 i have seen them go from 50~300 depending on style and condition Quote
Scoota G Posted March 19, 2014 Posted March 19, 2014 I would like to know where to get some of these $50 triple manifolds. Yell out if you see any!! Quote
