Hi I'm searching for a product I can use for all those hard to reach places like the Chanels in the roof and cavities under the door where getting to any rust is basically impossible. Something that I can spray in like an aerosol that attacks the rust but can be left in there with out being painted.
Any ideas?
You can buy Cavity wax in a aerosol that has a long flexible hose attachment that sprays 360 degrees for those hard to reach places. It seeps into all the cavities and stays tacky. Wurth makes a good one that doesn't leak out on a hot day.
Sounds like what I'm looking for is it penetrative? So like can I spray it ontosurfac rust and etc that might be down there?
Another one is Penetrol, it has a viscosity lower than that of water and goes into all the hard to reach places with a spray. Leave it for a few minutes, best over night, and it will harden for a nice seal.
Not very effective when exposed to UV but where you're talking would be perfect for it.
It can be found at your local Bunnings too which make it easy.
