peterrx5 Posted January 16, 2014 Posted January 16, 2014 I am after a set (4) of rims 15 x 7 with a PCD of 4 x 114.3 and a backspace of 110mm or less. They are for my car which requires a PCD of 4 x120 which is close to impossible to find, so I will need to have the rims redrilled. I already have a set of 15 x 6.5 which I have had redrilled, but they require spaces because of the incorrect offset/backspace which is a real pain. I live on the south side of Brisbane and am willing to do a local pickup or pay the courier cost if required. Hope someone can help me out with this requirement. Cheers Peter Quote
dat2kman Posted January 16, 2014 Posted January 16, 2014 Peter, Chris Neale at Revolution Wheels in Slacks Creek has the machinery to redrill. Have them done with his steel taper inserts, as these spread the force of the lug nut over a bit bigger area. I have a couple of sets of rims here, but biggest issue is making sore the recessed centre can take a pcd of 120, and give room for the socket over the lug nut. One set have a large enough centre facing, welcome to come by and inspect. Is there any benefit in converting front hubs/rear flanges to a more common size? Comes down to frequency of use vs effort and cost! Quote
sydney mike Posted January 17, 2014 Posted January 17, 2014 If you can't find anyone closer, try Neales wheels in Sydney http://nealewheels.com.au/ They manufacture/modify/repair wheels in-house. I had my watanabes modded there and found them really helpful. They have a lot of un-drilled 2 and 3 pieces wheels there so I'm confident they can knock up something for you in regards to pcd and offset. cheers, Mike. Quote
dat2kman Posted January 17, 2014 Posted January 17, 2014 Chis Neale, of Neales Wheels, ex Sydney, is now Wheel Revolution in Brisbane. Both shops can do all kinds of work on rims. Quote
Triptych Posted January 18, 2014 Posted January 18, 2014 I got the Nismo LMGT3 rims on my R32 cleaned up by Wheel Revolution and they did a great job. Located on Moss Street and they are very helpful down there just when I was there they didn't have eftpos so you had to walk upto shell and take money out Quote
