Cozza Posted January 18, 2014 Posted January 18, 2014 Yeah I got my Torsen type 2008 STi diff and the beta motor sports stub axles $1000 all up. The only down side was that I had to wait about 4 or 5 months for John to run another batch of the axles. So if you think you might go down that route then I recommend you follow the axles up first. As Jake mentioned the entire unit is newer than putting a new centre in an old K diff but I think the real benefit is that if you do blow a diff it is a reasonably cheap ($400-500) replacement unit once you have the stub axles. I'm really happy with mine. Quote
dat2kman Posted January 18, 2014 Posted January 18, 2014 Where in the ATB centre FAQ's list, does it tell you the answer to"what happens if you lift an inside wheel through a corner, ie off a kerb, or over mid corner bumps?" Yes extreme use, but when pushed in competition, and the majority dont, the operation of the atb/torsen etc type centres is not good. A Detriot Locker is better, in that situation! A number of users of these have experienced issues, and have reverted to the Clutch pack type centre. The ATB types are good, but dont push them hard. Quote
