wanta240z Posted September 10, 2007 Posted September 10, 2007 Hi, I am new to this site and looking for a 240 or 260z , one to do up while being a daily driven vehicle. maybe 6 or 7 k to spend tops... anyways, where are the main areas to look for rust and what other problems should i be on the lookout for. thanks guys Quote
FuzzyDropbear Posted September 10, 2007 Posted September 10, 2007 G'day mate, I don't know if these are the usual places but these are the places I have found rust on my z; top of the engine bay, below battery holder and around the bottom of the engine bay, bottom of the front guards, sills, bottoms of the door frames and around the hatch. Well, that's the major rust areas on my car anyway, also check around the floor if you can. Cheers, Rob Quote
reverendzed Posted September 10, 2007 Posted September 10, 2007 Good advice from Rob. Also be on the lookout around your fuel filler, this is a real problem with Zed's. The hatch sill above your tail lights is also another area that loves to give way to cancer and of course remember that what looks solid may have a great chunk of bog holding it all together! but then you are looking at a car that is 30+ years old. Good luck with your shopping. Rev. Quote
wanta240z Posted September 11, 2007 Author Posted September 11, 2007 great, thanks for the info. sounds like the old magnet in a rag is still a good idea, but some rust in a 30 odd year old car is to be expected !! Quote
Scando Posted September 11, 2007 Posted September 11, 2007 Worst places in mine were the floorpans and just in front of the rear wheels on the bottom of the guards. The bottom of the doors had a bit too. Quote
Zeddophile Posted September 13, 2007 Posted September 13, 2007 Another place can be the leading edge of the bonnet.... Pretty much every panel on a zed will rust, apart from maybe the roof. Usually on the lower extremities, IE door bottoms, floor, sills, bottoms of front guards.... Quote
