Most of the time they end up giving you worse performance than the stock airbox in my opinion. If you look at the stock airbox its not a bad design, with air horns for both the carbs which most aftermarket filters dont have.
If you just put a flat filter on the end of the carb it will be bad.
+1
Try ebay, there are K&N filters to suit the stock airbox. Flow much better than the originals and they can be cleaned/re-used many times with the K&N diy cleaning kit.
